I installed SQLBackupAndFTP about Christmas last year to automate my SQL Express backups. I never got around to fully testing it and testing a restore. When I decided to try to automate the backups again today realised that the service had been running in the background but failing to backup as the destination archive disk was full.
I tried editing the destination path but it still threw the same error reporting the old destination path.
I tried deleting that destination and adding a new one with the new path, same.
I tried un-installing the program with the delete back job data option ticked and re-installing, then setting a new Job, Same error. It is still trying to backup to the old now unused local archive disk.
As and update I tried searching the registry for X:\MSSQL\Backup and it only found an entry for SSMS.
Hi Leon_Coles,
It seems that the X:\MSSQL\Backup folder is used as your temporary folder and it can be changed at the “Temporary folder” section.
SQLBackupAndFTP works in the following way:
- Creates a backup file into a temporary folder
- Compresses the backup file into the temporary folder
- Removes the backup file after the compression
- Sends the compressed backup file to the selected destination places
- Removes the compressed backup file from the temporary folder
To resolve the issue, please set a temp folder that has enough free space to store the backup files and the compressed backup files at the same time.
