Sql backup and ftp - sql server 2019
Hi all,
Last week I installed the software (v. 12.5.13) to backup a database from SQL Server 2019 / Windows 2019.
The weird thing is, I ´m able to connect as ´sa´ user and test connection which is ok.
But it can’t see any database in the list while creating the backup job.
Anyone some solutions to point me the right way ?
Thanks in advance
Marlon
Hi Marlon,
Could you please execute the following SQL query:
SELECT name FROM sys.databases
using the same credentials to check if you can see all the databases?
While writing this I realized I´d used the wrong instance.
I changed it and viola.
Thnx anyway for your quick response last week.
Kind regards
Marlon
Hi Marlon,
