I have two instances running on my server 2016. When creating a job I connect to server x but after connection you choose the databases you want to backup it shows the databases from instance y (./sqlexpress). Restarting the software does not make a difference.
I’m seeing the same problem. But here are my relevant details:
Version: 11.5.2 Professional Trial Expires in 12 days.
In the SQL server instance drop-down, I can choose either the 1st or the 2nd and get a confirmation of the connection, but at the next step only the database(s) for the 1st instance is ever shown (regardless of which instance I chose).
@Jeff_Salisbury I installed the beta that was mentioned in another thread. And that did the trick. Now it works. This is the download link. https://www.dropbox.com/s/rsnf5o0y4uhyld5/RebexFtpClient.zip?dl=0
What other thread, please?
Also, why the beta download from Dropbox instead of sqlbackupandftp.com?
Just being careful!
@Mike_Oelen, that link doesn’t download a beta version of SQLBackupAndFTP. Did you accidentally provide the wrong link?
Hi Jeff,
Yes, it seems the wrong link. Could you please download the following version https://www.dropbox.com/s/44y9d38ev2y9jx8/SQLBackupAndFTP.exe?dl=0
We plan to release it until the end of this week.
This link fixed my problem!
Good news! Thanks for the feedback!
