Issues Backing Up Database Hosted on GoDaddy
I’ve been using SQLBackupAndFTP to create daily backups of a database hosted on GoDaddy for the last 2 years or so and have never had any issues. That has all changed within the last couple of months.
The logs being generated by SQLBackupAndFTP are as follows:
11/25/2025 9:16 PM Backing up “(insert IP address here)” Remote SQL Server databases.
11/25/2025 9:16 PM Backing up “(insert DB name here)” with “Full” backup type.
11/25/2025 9:16 PM Failed to backup “(insert DB name here)” database with “Full” backup type: Enum objects failed for Database ‘(insert DB name here)’. > Execute with results failed for Database ‘(insert DB name here)’. > An exception occurred while executing a Transact-SQL statement or batch. > VIEW SERVER SECURITY STATE permission was denied on object ‘server’, database ‘master’.
The user does not have permission to perform this action.
Does anyone know what permissions I need and where? And also, why I only just now need them?
Hi Joseph,
Thanks for your message.
We’ve just released an alpha build that reduces reliance on server-level permissions (e.g., VIEW SERVER STATE) and includes the latest fixes.
Download: https://sqlbackupandftp.com/download/alpha
You can install it over your existing setup—no uninstall needed.
It worked. I am able to once again create backups of my GoDaddy-hosted databases. Thank you.
Hi Joseph,
That’s great to hear — thank you for the update!
We’re glad the alpha build resolved the issue.
Your feedback helps us ensure the upcoming release is as stable as possible.
Thanks again for confirming!
