Error: StorageTrasnferOptions
We have been getting some failed backups to Azure with the following error information. Can you please advise how we might address these:
10/6/2021 11:21:06 PM [Error] Destination error: Failed to upload “S:\SQLBackupAndFTPTemp\Pranas.NET\SBF\040cfd65-290d-4ce1-9bd7-bb134839803a\backup\lme_1710202110062200.bak” file to “lme_1710” folder. > Cannot upload 107176193536 bytes with a maximum transfer size of 2143523 bytes per block. Please increase the StorageTransferOptions.MaximumTransferSize to at least 2143524.
Any update on this issue? Still suffering the same issue.
10/11/2021 11:38:59 PM [Error] Destination error: Failed to upload Cannot upload 107648869376 bytes with a maximum transfer size of 2152977 bytes per block. Please increase the StorageTransferOptions.MaximumTransferSize to at least 2152978.
Hi Brett_Slaght,
Could you please let us know what version of SQLBackupAndFTP do you use? If you use an old version (older than 12.6.3) then please upgrade it to the latest release by clicking the “Help” > “Check for updates” and check if it works for you.
We have same problem with few databases in one of the servers. SQLBackupandFTP tool version 12.6.3 . Any other suggestions? It started at Oct 7 also, so maybe MS did something in the background.
Hello guys,
We have just released the Alpha edition, could you please install it and check if it works for you?
