Hello, long-term users of your SQLandBackup software. There was a problem with the disk of the computer I was using, and I recovered the data on it. I want to reinstall your software, but how can I import the data I used before? In other words, how can I import existing data from the files from which I recovered the data? Where is the data stored? can you help me?
Hello Mehmet_Akif_SARI,
The data is stored in the following folder: C:\ProgramData\Pranas.NET\SQLBackupAndFTP
Additionally, you can use Configuration Manager (“Tools” > “Configuration Manager”) to export/import your settings.
