When I test connection it works ok but I can't save the job
Using SQLserver I can set up A a job and test it and it works.
I can also run the job and it works but I can’t save the job because it asks for a password.
It obviously works perfectly well without a password so why do i need one to save the job?
in the FAQ it says to copy my normal connection which is using windows authentication without a password.
I can’t use a password on my PC as for some reason I can’t connect to another PC on my network if I use one ???
Mike
Hi Mike,
I’m sorry, but it is not possible to establish a connection without a password. To address this issue, please create a user account with a password.
If you have any further queries, please do not hesitate to contact us.
Thank you and apologies for any inconvenience caused.
