Hi
I have a signicative amount (+1000) of database to backup from multiple server.
How can I import configuration to do it quickly instead of using GUI ?
I see the sbf file import/export method but I can’t open it to work directly inside.
Thx for your help
Hi matth33,
The exported configuration contains data in the internal format of the program, editing of which manually is not expected and will most likely lead to the inoperability of the application.
To work with a large number of databases, we recommend using the “Exclude databases” option (at the “Select Databases” window), which can help to group databases by jobs.
