Volume Shadow Copy for Folder Backup
Hi
I have some customers that use the nice folder backup function.
But on some days, when the user do not close some specific software, .db files are not accessible for backup because it is used from another process.
ERROR: Failed to backup “\fileserver\folder\subfolder…”. Xceed archiver error. The file item could not be opened for reading. Type: Xceed.FileSystem.DiskFile FullName: \fileserver\folder\subfolder…\filename.db
Der Prozess kann nicht auf die Datei “\fileserver\folder\subfolder…\filename.db” zugreifen, da sie von einem anderen Prozess verwendet wird.
Maybe it would be a nice feature to add volume shadow copy options for the folder backup?
Regards
Michael
Hi Michael,
SQLBackupAndFTP was designed to backup DBMS, option, that allows backup local files and folders is additional, but thank you for the feature request.
