Upload backups per SFTP
I would like to upload backups via SFTP protocol but in the backup log there is an error message:
3/13/2019 10:53:24 AM [Error] Destination error: [DST-2:1001#101101011] Failed login to … destination. > Rebex SFTP/SSH does not support FTP or FTP/SSL protocol. Use Rebex FTP/SSL component instead.
Same when I try to test the connection.
I’m using 12.2.3 - Standard license.
Can anyone help?
Hi Michael_Remmel,
Could you please make sure that you have specified only your host address at the “Host Address” box, you can specify a Protocol and Path at the “Advanced FTP Server settings”.
