Test failed. psql: error: could not connect to server: SSL connection has been closed unexpectedly (Postgres)
Hi there!
I’m trying to connect to postgres db using SBF I entered the db credentials (host - port - username - password) when I click test connection it fails because the default DB name is set as ‘postgres’ and I can not access to this db, I need to change db name to be able to connect to my own db using the credentials.
Hi Haradd_Haead,
Sorry, currently there is no way to do it, thank you for your request, we have forwarded it to our dev team for consideration.
