Buen día mies estimados compre una licencia pero la intención era usar la herramientas para automatizar el backup, encriptar y traslado a un repositorio en red pero cuando configure mis procesos algunas veces lo hacia y otras no con el error de fallo transferencia. necesito saber si esta heramiento solo sirve para procesos local o hay alguna configuracion adicional que permita el ejercicio de desde un host se ejecute la herramientas para distintos servidores en red.
We recommend running SQLBackupAndFTP locally on each server that you want to backup, as this usually provides the most stable and reliable operation.
It is possible to backup databases from other servers over the network, but this depends on your environment’s configuration — for example, network speed, reliability, firewall settings, and user permissions. If you are experiencing intermittent “transfer failed” errors, it’s often due to network interruptions or restrictions.
For best results, please install the application directly on the server hosting the database.
Also, please note that scripting-based backups (using generated SQL scripts) are generally less stable and reliable compared to standard .bak file backups.
