I’m on 9.1.26.26577
It’s been backing up fine to Amazon S3 for a while fine. Is there a way to also put a copy of all the backup files on the local machine too?
Thanks.
I’m on 9.1.26.26577
Thanks.
Hi Nick,
You use a very old version which is no longer supported and we recommend you to upgrade to the latest version - 11.4.4. You can do it at your “My Account” https://sqlbackupandftp.com/account page, by clicking the “Upgrade” button. Use the email you have used to purchase SQLBackupAndFTp to sign in.
To add another destination place for your backup, just go to the “Store backups in selected destinations” section and click “Add backup destination” then select “Local/Network Folder”.
Thanks.
What benefits do I get from upgrading?
Hi Nick,
You can find what is new and what is missing in the new version at: https://sqlbackupandftp.com/blog/sqlbackupandftp-11-differences
Also, we recommend you to check the following blog post: https://sqlbackupandftp.com/blog/sqlbackupandftp-11
