ERROR: Backup of sr_task failed: mysqldump: Got error: 2026: SSL connection error: protocol version mismatch when trying to connect, can any one please let me know how to solve this?.
Hello Prashanthi,
The issue is likely related to the version of your MySQL server being different from the binaries that are installed with MySQL.
Please download the MySQL binaries that match the version of your server, ensure that you can connect manually using the mysql.exe utility, and then specify the path to the directory with these binaries in the connection settings of SQLBackupAndFTP.
