So, a while back (several months ago) I updated this application, and it broke. I tried reinstalling several times, installing the old version, etc., and nothing appeared to work. I removed all the jobs, and directories, and removed all references in the registry, and still nothing.
I lost track of this issue, and that was stupid, because if things go sideways, I’ll be in serious hot water.
SqlBak.Job.Cli fails for this, and so does SBF.Migration (just ran both for fun).
Here’s what I’m seeing in the logs (multiple errors):
Error 1:
Faulting application name: SqlBak.Job.Cli.exe, version: 2.13.0.0, time stamp: 0x5f439643
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0x80131623
Fault offset: 0x00007ffd83c0878f
Faulting process id: 0x21f0
Faulting application start time: 0x01d67cb5d63bd4f0
Faulting application path: C:\Program Files (x86)\SQLBackupAndFTP\SqlBak.Job.Cli.exe
Faulting module path: unknown
Report Id: 1531e277-e8a9-11ea-80e1-002590de476e
Faulting package full name:
Faulting package-relative application ID:
Error 2:
.NET Runtime version 4.0.30319.0 - Loading profiler failed during CoCreateInstance. Profiler CLSID: ‘{e8d20431-3c3d-3c3d-3c3d-a69a6a9910fe}’. HRESULT: 0x8007007f. Process ID (decimal): 8688. Message ID: [0x2504].
I gave up on this out of frustration, and had other things to do, but I seriously need to get this back up and running! Help!
I should note that I have just installed .NET 4.8, with no change.
