Hi there
We’ve had an restore problem on MSSQL for linux server running in Docker. You’ve adviced us to use the https://hub.docker.com/r/pranasnet/sqlbak software to fullfill the backup. Now I’ve a few questions about it:
Situation:
We’re running multiple docker containers each with an mssql-express instance on a linux server.
Each of the docker-containers shares the database files on the host in the destination /home/sysadmin/dockerdata/db_xxx (for each instance there will be an subdirectory.
Questions:
- What’s the “best” way to backup all the instance-database-files with your tool? Running the Tool itself in docker? Is there a container for each mssql-docker-container needed or can we catch-it all at once?
- The configuration with this (xxxx is not correct but we’ve got the correct number):
sudo docker run -e sqlbak_key=‘0cb14dab-671e-4cc1-a560-xxxxxx’ -e sqlbak_name=dashboard_db_testrestore_ -e dbtype=mssql -e user=sa -e ‘SA_PASSWORD=.amv1234’ -e host=ubuntu64test -v /home/sysadmin/dockerdata/sqlbakdata pranasnet/sqlbak
-> it gives us an Command-Error that the connection is not configured… How can we manage this correctly? See uploaded image. There will be a few parameters missing? Where to correct those?
------------------- Screen
sysadmin@ubuntu64test:~$ sudo docker run -e sqlbak_key=‘0cb14dab-671e-4cc1-a560-db859587eb16’ -e sqlbak_name=dashboard_db_testrestore_ -e dbtype=mssql -e user=sa -e ‘SA_PASSWORD=.amv1234’ -e host=ubuntu64test -v /home/sysadmin/dockerdata/sqlbakdata pranasnet/sqlbak
- ls -A /opt/sqlbak
- cd ./etc/sqlbak
- ./sqlbak --start
- [ -z 0cb14dab-671e-4cc1-a560-db859587eb16 ]
- allvar=1
- [ -z mssql ]
- [ mssql = postgres ]
- [ -z sa ]
- [ -z ubuntu64test ]
- [ -z ]
- [ mssql = mysql ]
- [ mssql = postgresql ]
- [ mssql = mssql ]
- port=1433
- prw Register on [link deleted]
- echo -e \e[33mRegister on [Link deleted]\e[0m
-e Register on [link deleted] - [ -z dashboard_db_testrestore_ ]
- ./sqlbak --register --key=0cb14dab-671e-4cc1-a560-db859587eb16 --name=dashboard_db_testrestore_
Handling a console command has failed. Failed to register this server. Failed to register this server. Failed to make a request to remote server. PSB:0002 Failed to register a new server. Please try again or contact the service provider.
PSB:0006 Failed to register server “dashboard_db_testrestore_”. The server with the same name is already connected. Please change the name and connect again… . . - [ 1 = 1 ]
-e Add conection - prw Add conection
- echo -e \e[33mAdd conection\e[0m
- ./sqlbak --add-connection --db-type=mssql --user=sa --password= --host=ubuntu64test --port=1433
Invalid syntax. It must be either --<param_name>=<param_value> or -<short_param_name> <param_value>.
Syntax error. Unknown command. - set +o xtrace
------------------------------------- End of screen…
Kind regards
Ruedi Neff
