SQLBackupAndFTP.exe expired certificate
Hi!
I have a problem running SQLBackupAndFTP.exe, the error that is displayed is “This app has been blocked for your protection”
I tried to disable antivirus, UAC, SmartScreen, but none worked.
When I inspect the EXE file, I see that the certificate has expired - could this be the problem?
File version is 8.1.1.0
We are currently without backup, so please help!
Hello Marko_Milutinovic,
It appears that you are using a very outdated version of SQLBackupAndFTP. Could you please install the latest release, version 12.7.18, and check if it functions correctly for you?
If you have any other questions, please do not hesitate to reach out.
