Restore of SQLServer database restores with a different name if database name contains a dot. For example, “Test.DBName” restores as “Test_DBName”.
Searched the forum, found a PostgreSql reference, but none for restoring a DB with its original name for recovery server. Might be missing something.
Also thanks for a great job.
Hello Michael_Nourani,
We have investigated the issue and can confirm that everything is working smoothly. If a database contains a dot in its name, it will not be replaced with an underscore during the restore process; the name will still contain the dot.
If you continue to experience this problem, please provide us with more detailed information about how you are performing the backup and restore.
