• 10:30:02 AM : Starting scheduled job “Kseeker_Scheduled_Job” - “Full”. Server “TSDS”. Account “SYSTEM@TECHNO-SOFT”. App v.“12.4.8”.
• 10:30:07 AM : Connecting to: (5.7.27-log). 40.121.36.230.
• 10:30:09 AM : The backup folder “C:\Windows\TEMP\SYSTEM\Pranas.NET\SQLBackupAndFTP\backup” has “71.72GB” free space. The temporary folder “C:\Windows\TEMP\SYSTEM\Pranas.NET\SQLBackupAndFTP\backup” has “71.72GB” free space.
• 10:30:10 AM : Backing up “40.121.36.230” databases with “mysqldump.exe: Ver 8.0.13 for Win64 on x86_64 (MySQL Community Server - GPL)”
• 10:30:12 AM : The maximum file size for destination “Google Drive: Knowledge Seeker”: “4.768TB”.
• 10:41:05 AM : ERROR: Failed to backup “ksbronx” database with “Full” backup type: mysqldump: [Warning] Using a password on the command line interface can be insecure. mysqldump: Couldn’t execute ‘SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, ‘$.“number-of-buckets-specified”’) FROM information_schema.COLUMN_STATISTICS WHERE SCHEMA_NAME = ‘ksbronx’ AND TABLE_NAME = ‘attendance’;’: Unknown table ‘column_statistics’ in information_schema (1109) mysqldump: Couldn’t execute ‘SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, ‘$.“number-of-buckets-specified”’) FROM information_schema.COLUMN_STATISTICS WHERE SCHEMA_NAME = ‘ksbronx’ AND TABLE_NAME = ‘certification’;’: Unknown table ‘column_statistics’ in information_schema (1109) mysqldump: Couldn’t execute ‘SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, ‘$.“number-of-buckets-specified”’) FROM information_schema.COLUMN_STATISTICS WHERE SCHEMA_NAME = ‘ksbronx’ AND TABLE_NAME = ‘certificationcourses’;’:…
• 10:50:45 AM : ERROR: Failed to backup “ksqueens” database with “Full” backup type: mysqldump: [Warning] Using a password on the command line interface can be insecure. mysqldump: Couldn’t execute ‘SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, ‘$.“number-of-buckets-specified”’) FROM information_schema.COLUMN_STATISTICS WHERE SCHEMA_NAME = ‘ksqueens’ AND TABLE_NAME = ‘attendance’;’: Unknown table ‘column_statistics’ in information_schema (1109) mysqldump: Couldn’t execute ‘SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, ‘$.“number-of-buckets-specified”’) FROM information_schema.COLUMN_STATISTICS WHERE SCHEMA_NAME = ‘ksqueens’ AND TABLE_NAME = ‘certification’;’: Unknown table ‘column_statistics’ in information_schema (1109) mysqldump: Couldn’t execute 'SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, ‘$.“number-of-buckets-specified”’) FROM information_schema.COLUMN_STATISTICS WHERE SCHEMA_NAME = ‘ksqueens’ AND TABLE_NAME = ‘certificationcourses’…
• 10:53:08 AM : ERROR: Failed to backup “tlc_prod” database with “Full” backup type: mysqldump: [Warning] Using a password on the command line interface can be insecure. mysqldump: Couldn’t execute ‘SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, ‘$.“number-of-buckets-specified”’) FROM information_schema.COLUMN_STATISTICS WHERE SCHEMA_NAME = ‘tlc_prod’ AND TABLE_NAME = ‘aggregatedcounter’;’: Unknown table ‘column_statistics’ in information_schema (1109) mysqldump: Couldn’t execute ‘SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, ‘$.“number-of-buckets-specified”’) FROM information_schema.COLUMN_STATISTICS WHERE SCHEMA_NAME = ‘tlc_prod’ AND TABLE_NAME = ‘counter’;’: Unknown table ‘column_statistics’ in information_schema (1109) mysqldump: Couldn’t execute ‘SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, ‘$.“number-of-buckets-specified”’) FROM information_schema.COLUMN_STATISTICS WHERE SCHEMA_NAME = ‘tlc_prod’ AND TABLE_NAME = ‘delmetest’;’: Unknow…
• 10:53:10 AM : Cleaning up backups of “Kseeker_Scheduled_Job” job.
• 10:53:12 AM : ERROR: Job “Kseeker_Scheduled_Job” finished with “3” errors
kindly anyone tell me the solution??
