SQL Backup And FTP 12.7 crash database mysql Event Viewer 1026
Event Viewer Error 1026 with Windows Server 2012 R2.
I am having 1026 Net Runtime error in Windows Server 2012 R2 event viewer.
I have all Net Framework installed up to 4.8.
I have Visual C++ Redistributable up to 2022 installed and updated from 2015 to 2022. I have also installed 2005, 2008, 2010, 2012 and 2013.
I’ve already restarted the server and I’m still having the problem of crashing the application when making the backup. I’m thinking of installing the pre-12.7 version for netframework 4.6 to see if it will work.
I already ran the microsoft netframework hotfix and it told me I needed to fix netframework 4.8 and I fixed it and restarted the server.
I already uninstalled and installed SQLBackupAndFTP, I don’t know what it could be. Does anyone have any suggestions?
Hello Alex_Silva,
It seems the issue you get is generated by other software and not by SQLBackupAndFTP. Sorry, but the issue cannot be resolved from our side.
SQLBackupAndFTP interacts with MySQL via the mysql.exe utility and not MySQL.Data.net library.
In fact, the error was with this code 0x80004005, I looked on the internet and solved it by adding the line to the program.
default command timeout=120
Leaving it here in case other people may have the same problem I had.
Thank you for your reply Alexander
Hello Alex_Silva,
Good news!
Sure, thank you for the update.
