SQLbackupandftp-service does not start automatically after restart of the computer. Manual start ist working. No log-entry found in windows-event-log. Please try to help. Thank you.
Thank you for the issue reporting.
If it happens during the server’s restart, then please open Windows Services window and find SQLBackupAndFTP (SQL Server backup) Windows Service, right click and select “Properties” in the opened window please select “Automatic (Delayed Start)” at the Status type section.
Also, SQLBackupAndFTP (SQL Server backup) Windows Service can be blocked by antivirus or any other security software.
Should note, that updates to the application will reset your delayed start override. I’ve been caught by this several times.
Thank you for the issue reporting. Please give us some time to check and fix it.
