We use the backup software to back different environments. I would like to be able schedule a restore just like a backup.
This would allow me to move production data to test environment automatically.
If this is already available, I can’t find it.
Hi Chris,
Sorry, but there is no such option in SQLBackupAndFTP, we can recommend you to create a restore job and run it via Command Prompt using Windows Scheduler. Here are more details on how to run a backup job via Command Prompt https://sqlbackupandftp.com/blog/run-sqlbackupandftp-v11-command-line To run a restore job just use the following command:
SqlBak.Job.Cli.exe -runJob -jobName "Job"
Also, you can try our another product - SqlBak https://sqlbak.com/ it allows you to add a restore process to your backup job, just set an appropriate settings at the “Restore on another computer” section.
Hi
i used the command line but i got this error
10/17/2019 12:38:35 PM [Error] Failed to restore laundry_db database. Access to the path ‘C:\WINDOWS\system32\laundry_db20191017123057c618b1-7602-4acb-bef3-faefdaeaa209.sql’ is denied.
i changed the temporary folder setting in the job but it is not reflecting
THIS IS THE FULL REPORT
10/17/2019 10:05 AM Connecting to MySQL Server: (5.6.41-84.1). domain.biz
10/17/2019 10:05 AM Connecting to FTP destination “ftp.domain.biz”
10/17/2019 10:05 AM Searching files by mask “laundry_db*”
10/17/2019 10:05 AM Found “4” files.
10/17/2019 10:05 AM Restoring “widetech_landdb” database on “Thursday, October 17, 2019 12:57 PM” from backup of “laundry_db” database
10/17/2019 10:05 AM Downloading file “laundry_db201910171257.zip” to “F:\temp_upload\Pranas.NET\SQLBackupAndFTP\backup\0f4ba1c3-01ed-4622-b7b3-a9204e801495”
10/17/2019 10:05 AM Uncompressing “F:\temp_upload\Pranas.NET\SQLBackupAndFTP\backup\0f4ba1c3-01ed-4622-b7b3-a9204e801495\laundry_db201910171257.zip” file with Internal archiver.
10/17/2019 10:05 AM Restoring “widetech_landdb” database from files: “laundry_db201910171257.sql”
10/17/2019 10:05 AM Failed to restore laundry_db database. Access to the path ‘C:\WINDOWS\system32\laundry_db201910171257c73153e0-a3ce-42dc-b6ec-690b9e4062d2.sql’ is denied.
10/17/2019 10:05 AM Disconnecting from FTP destination “ftp.domain.biz”
10/17/2019 10:05 AM Job “restore1” finished with “1” errors
Hi Sayed_Mohamed_Ameen,
Thank you for the details, please give us some time to check the issue.
Anything Happened regarding this issue?
It seems this issue related to your user permission settings. Could you please try to run the following command:
SqlBak.Job.Cli.exe -runJob -jobName “Job”
from behalf of the user that has enough rights?
