Restore of PostgreSql database does not work if database name contains a dot. For example, if the database Name is “mydatabase_2.1” the restore will fail. If the database Name is “mydatabase_2_1” it will work.
Hi Richard_Mueller,
Thank you for the issue reporting. Please give us some time to check and fix this issue.
Hi Richard_Mueller,
We have added some changes to SQLBackupAndFTP Alpha version https://sqlbackupandftp.com/download/alpha could you please install it and check if the issue is resolved?
The issue is solved with the provided Alpha Version. Thank you very much vor the prompt Support.
Hello Richard_Mueller,
