Hi for now SBF just let us restore one DB at one time, sometime the Instance have multiple databases (etc 40+ more DBs in one instance) so it will take time to restore all those DBs. Can we have the feature which let us check which one will be restore?
To restore multiple databases simultaneously, you can use the Restore Job feature. This allows you to specify all the databases that need to be restored. Simply click the “Add all” link in the Restore Job configuration to include each database you wish to restore (see the screenshot for reference).
Hello, is this multiple‑restore functionality available for MySQL databases? Additionally, is it supported under the standard license?
Hi George,
Yes, the multiple database restore with selection is supported under the Standard license and works for the following engines:
- MS SQL Server
- MySQL
- PostgreSQL
