Restore Job - No databases to restore
When creating a new Restore Job, after specifying a ‘Take backups from’ location and connecting to a Server, there are no options in the ‘Select databases to restore’ list despite there being many databases running on the server. The version of sql server is 14.0.1000.169
Could the issue be that the application cannot read from this version of sql?
Clifford
Hi Clifford,
Could you please clarify your question?
If you need to restore a backup from a file then the backup will be restored in the database with the same name, if such database doesn’t exist it will be created. Also you can change the database’s name to which it should be restored.
