I want to create a separate user for back up and restore. This needs to be a read only user. What privileges and type of user is needed for sqlbackupandftp to work? Is there a ready script that I can use to do this?
Hi Nikhil_Ramabhadra,
Please give us some time to check the issue, we’ll keep you updated.
Thank you for waiting.
To create a backup, you need read permissions. Also, for the correct work of the application, you have to have all the permissions for the postgres database. This is required to execute a query for the list of databases:
SELECT datname FROM pg_database.
