After upgrading to the latest version (12.7.23) backup jobs failed with message
postgre connection error -1073741511 (pict1).
Before upgrading Backup job worked correctly for more then 2 years.
PostgreSQL is located on Linux server (CentOS 7).
SQLBackupand FTP installed on Windows 2008 R2 server
Hello Sergey1,
Could you please navigate to your connection settings, click on the info button, copy the command, and then run it using the Command Prompt to check the connection?
Please ensure that you have specified the password during the connection via Command Prompt.
If you have any further questions, please feel free to ask.
I managed to solve the bug.
In my case the problem apperared when I check in the option “Automatic updates” and the last version Sql Backup And FTP installed.
It turned out that the last version Sql Backup And FTP is not fully compatible with Windows 2008R2. There are 2 workarounds: to roll back to the old release, or move program to another server with Windows 2016 or later
Hello Sergey1,
Good news! Thank you for the update.
