I may have missed this, but is there a way to password protect the console? If a hacker got access to a server with the console installed they could delete all of the remote backup files via the console… A password on the console would help protect remote backup files from deletion.
Hi Spencer_Schultz,
There is no way to remove the backups via the console. Also, but there is no way to set a password, but thank you for the feature request, we’ve forwarded it to our dev team for consideration.
We’d like this feature as well, we had a complain with a customer of ours because one user managed to change the settings of the FTP destination server. It would be very useful to have a password to lock backup settings!
Hope it will be implemented soon.
Thanks!
Hi Andrea_Di_Martino,
Thank you for your feature request, but sorry, currently we do not have any plans to add this option.
I was deciding to buy but, when I noticed that anyone can change the password, I decided to postpone the purchase. I think it is important because it is a commercial software that I will place on a client to prevent access to the data structure. I had a case of passing on the data to a competitor.
Hi AFONSO_CELSO_DA_SILV,
Thank you for the details, we’ll consider it.
