Old backup cleanup
We’ve set up old backup deletion for S3 Compatible storage like this:
Jobs run successfully but it doesn’t delete old backups.
Regards,
Serge D
Hi Serge,
We have checked the issue and can confirm that the auto-delete option works smoothly.
Note, that according to your schedule settings the backups should be removed on the 4th day during the next run of your backup job.
If you still have any issues, then please check if the backups that should be removed are located in your destinations.
