I have just downloaded an evaluation of sqlbackupandftp v12.5.5. I have connected to the server without issue (Test OK) but I get no databases listed to under Select Databases. Is there something I am missing?
Hi Mark_Wortley,
Could you please go to your connection settings, press on the info button, copy the command and run it using the Command Prompt. Please let us know if the databases are there.
Please make sure you specified the password during the connection via Command Prompt.
