Came across this SQL backup software and had a few questions.
Little background on our setup. It’s a Windows server 2022 machine running SQL server 2014 Express with only one SQL database. We might be switching to SQL server 2022 Express soon.
Can I set two different backup methods? For example, a local and back blaze at the same time?
Is there any way after a backup for it to test the backup of file itself? From whatever it’s a good rule of thumb to always check your SQL backup files.
Is there an option to also backup non-SQL folders and files? Reason I ask is because on these workstations I need to backup SQL database (2014 express) and a specific folder for the software which uses SQL. Trying to minimize the amount of backup software being used.
Also, do I have to change anything in the Windows 11 power settings so the PC doesn’t go into Hibernation or Sleep when it backs up around 9pm every night?
@Alexander Hey Alexander, just following up to see if a response may be provided. We plan to backup on 2 separate machines their SQL databases onto our local drive. Then I have a backup software that will transfer that file to our local NAS. I just need to make sure the Lite version can restore verifyonly and checksum as well. Please confirm.
Could you please check your Advanced Backup Schedule settings? It’s possible that you enabled the “Run between” option, but the time you set in the “First full backup start” doesn’t align with the time interval you set in the “Run between” option. Could you please verify this?
