Hi. We’ve already mentioned a couple of missing options in the application, but from day to day it becomes more and more critical due to intensive usage of the PostgreSQL for big databases.
The previous were created by our DBA and can be found using following links:
Currently the missing options are:
Using folders for jobs
Sorting jobs by name
Scheduler for restore jobs
Possibility to perform point in time backup/recover for the PostgreSQL databases, using for example pgbackrest besides pg_dump
PostgreSQL 13 support (during the automatic updates the PostgreSql directory is being updated with the pg_dump 12 binaries and we have to disable the automatic updates or every time replace the binaries after the update
Please feel free to communicate with our contact person via mail as soon as we have the email support due to using the professional version.
We will be glad to have an additional notification if this feature will be considered. I think it will be wery helpful to manage the multiple jobs within the app
Thanks a lot. We will be glad to get an update once it will be implemented
Works like a charm! Thank you!
We will be more than happy to get an update once it will be implemented
We will be glad to get an update once it will be implemented to re-enable the automatic updates
