Backup stops every time after 300 seconds.
Where is it possible to change the 300 seconds.
In then sbf.log there are multiple lines with "Return (the waiting period “300"sec has not expired yet)”
At the end of the last backed up file there is.
[type] => 1
[message] => Maximum execution time of 300 seconds exceeded
[file] => /usr/local/apache/htdocs/adv,/pkg/phpmyadmin/libraries/plugins/export/ExportSql.class.php
[line] => 1810
I am using MySQL
Is there a possibility to change this in the Timeouts.xml?
