I have you have ssh through password and it is mostly unsecured method to login.
Pls add key based ssh login also.
Hi KARTHIK_KUMAR_NADAR,
Could you please clarify your request? Do you need this feature to connect to the databases’ server or to connect to an FTP Server?
Basicly most of us we block the server from accessing directly from outside and disable password login.
So pls add the feature so the we can login through ppk or from key to login to the server and then connect to the server
Thank you for your reply. Could you please clarify, to what database server do you prefer to login through ppk or from key?
Database server do you prefer to login through ppk
database server prefer to login through ppk
Could you please clarify, is it PostgreSQL Server or MySQL Server?
IT IS MYSQL SERVER
Thank you for the details. We’ll consider that request.
