"Login Failed" on SQL Developer edition 2017
Hello, im not able to login to SQL developer server even-thought the same credentials are working fine on SSMS.
is their any restrictions on that?
Hi Hadi_Hasan,
There are no restrictions. Could you please try to specify user with the domain if you use Windows Authentication.
Thanks for your reply… im using server authentication which is working fine on SSMS and on the application connection string but not working on sqlbackupandftp … the previous version of sql express was working fine.
what shall i do?
The weird thing is that the same credentials are working when accessing using sql remote but not working using local authentication.
we have the express version and developer version of the sql on the same machine.
Hi Hadi_Hasan,
Appreciate your response with the detailed information!
Please give us some time to check the issue.
Still Waiting your update
Hi Hadi_Hasan,
We have checked the issue, but sorry we were not able to reproduce it. We can provide you with the following recommendations:
  1. Please try to use Microsoft SQL Server (local) connection and Windows Authentication. Do not click on the “Test Connection” button, but run a backup job to test if it works.
  2. Send us the advanced log:
    a. Reproduce the issue with Microsoft SQL Server (local) connection
    b. Connect using the data for Microsoft SQL Server (remote) connection
Here are more details on how to send the advanced log to our dev team https://sqlbackupandftp.com/blog/how-to-send-log-to-developers
Please let us know when the log will be sent. Also to identify it we need your Application ID (“Help” > “About”)
If you have any other questions, please feel free to contact us.
Advance log Sent Please let me know the updates
Hello Hadi_Hasan,
Thank you for the logs, please give us some time to check the issue.
For further investigation could you please provide us with your Application ID, you can find it by clicking “Help” > “about”.
9c800ea7-5641-454d-bd81-51dfb46a4861
Thank you for the details, we are working on the issue.
Hi Hadi_Hasan,
Thank you for your waiting.
We have fixed the issue in the Alpha edition. Could you please install it http://sqlbackupandftp.com/download/alpha and check if it works?
Sorry for the inconvenience and for the delay.
The licence that i have will not work for this version
Hello Hadi_Hasan,
You can remove the license key from the application (“Help” > “License” > “Remove license from this computer”) and run the Alpha edition to check if it works for you.
