I’m just reviewing this product. v11.7.3
I need to export 300GB of SQL data at a time to a local drive. The problem is that this product double handles the data and a 4hr export takes 8 hours.
Is there a way to configure the product to move from the Temp directory instead of copy? (send to destination)
or alternatively can we export the SQL direct to a location without the Temp directory?
Cheers,
Nathan
