Is there a way to generate the backups in .SQL files when I’m not remote?
Hello Moses_Schwartz,
Yes, you can do it, just use “Microsoft SQL Server (remote)” server type and specify a connection to your local SQL Server using User Name and Password for SQL Server Authorization.
