Job failed - don't see errors
I have a job running on a server that shows Job Status: Failed. If I scroll through the detail, I see a green check mark on every line. If I export and search for “fail”, I find nothing. How can I know what is failing if not in the logs?
Could you please tell us what version of SQLBackupAndFTP do you have and do you use Web Log feature?
