Hello.
Im current testing this tool.
We have the following database servers.
Azure SQL
MS SQL
MySQL
Azure SQL and MS SQL are working as intended and i have tested back and restores.
MySQL server seems to have an issue where the connection when tested fails instantly.
to me it doesn’t even look as it the application is trying to make the connection.
it make no difference what server address i put in the application fails.
I have installed the latest C++ redistribution as suggested.
this is a windows 2019 Data Centre version with the latest windows updates installed.
Any suggestions ?
its a shame really.
this application seems to work so well for the MS SQL and Azure SQL.
But it cannot work with MySQL then its of little use for me.
I will start looking elsewhere.
Hello Colin_Kent,
To resolve the issue, please try to specify the path to your bin folder in the advanced connection settings.
Hello Alexander
the setting is currently blank
if i change it to be this
i get this error
Sorry as a new user it will only allow me one screenshot per post
Just for clarification
this is a remote MySQL server and im trying to connect over IP
the machine on which the application is installed is a Windows server which has NOT got MySQL installed.
is this something i need to do ?
I only have 6 days left on my trail for this product.
i’d really like to get this resolved.
Hello Colin_Kent,
Thank you for the clarification.
It seems you have specified the incorrect path; the path should lead to the bin folder of MySQL, not the folder where SQLBackupAndFTP is installed.
If you are connecting to a remote MySQL Server, please install MySQL Workbench on the computer where SQLBackupAndFTP is installed and then specify the path to the bin folder of Workbench (for example, C:\Program Files\MySQL\MySQL Workbench 8.0 CE.
We can extend the trial upon your request. To do so, please provide us with your App ID (“Help” > “About”).
Hello.
Thanks for that information.
i have now managed to move forward.
Why is this information not readily available ?
Can i get an extension for application ID
bc618117-c814-4f14-ad9e-a130d3ed55ba
Cheers
Colin.
Hello Colin,
Thank you for the details. The trial for your installation has been extended until December 12, 2023.
