Importing same .jobx twice does not create a unique Job
I have an old .jobx file which I would like to import 2 or 3 times to retain FTP and email settings. When a file is imported, a new job is created, but it looks like the import is using the same Internal ID for both import then when making changes to one job, these are done to the other job.
Desired functionality is that each .jobx file imported should generate a unique Job record that should not be affected by subsequent .jobx imports.
Also, it would be nice to have a way to duplicate or copy a Job, for the same reasons to be able to re-used previous configurations for FTP, DropBox, emails, etc.
Thanks!
Thank you for the features requests, we’ll consider them.
Also, is there a way for me to modify any imported Job to make it unique now?
Where is the data for jobs being stored?
Thanks!
Please try to delete existing backup job destination places and create the new ones.
Thanks, I will do so.
