que version deberia comprar para subir el backup por onedriver, gracias
Hi Ricardo,
To send backups to OneDrive Personal, you can use any edition, even Free. If you need to send backups to OneDrive for Business, please use Professional or Professional Lifetime editions. You can find more details at https://sqlbackupandftp.com/features
Hola , cual es el motivo, que los backup mssql comprimido con zip son mas grandes que con rar
gracias
Hi ricardo,
This is due to the fact that they have different compression algorithms, which can compress different data in different ways. For the maximum compression, we recommend you use 7zip.
