A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
Hello there, what connection failed? The one to the database or the one to the destination where you are saving the backup?
Please have a look at the logs.
DETAILED LOG:
11/05/2019 01:00:27 Creating backup of ******** to E:\TEMP\Pranas.NET\SQLBackupAndFTP\w2v32ssv (full)
11/05/2019 01:00:35 Connecting to E:\SQLBackup
11/05/2019 01:00:35 Uploading *201911050100.bak to E:\SQLBackup (
11/05/2019 01:00:42 Remote file size has been successfully verified
11/05/2019 01:00:42 Disconnecting from E:\SQLBackup
11/05/2019 01:00:42 Connecting to ftps://10.10.88.225:991/
11/05/2019 01:01:25 ERROR: Backup failed > "SBFDS1002": Destination exception > A connection attempt failed because the connected party did not
Hi sandeep_singh_verma,
Could you please clarify what version of SQLBackupAndFTP do you use?
