Hello can you help in this problem
4/11/2021 11:09:50 PM [Error] Failed to backup “gs_db” database with “Full” backup type: mysqldump: [Warning] Using a password on the command line interface can be insecure.
mysqldump: Error 2013: Lost connection to MySQL server during query when dumping table gs_object_data_027046523304 at row: 15574
mysqldump: Couldn’t execute ‘show table status like ‘gs_object_data_027046523320’’: MySQL server has gone away (2006)
mysqldump: Couldn’t execute ‘SET SQL_QUOTE_SHOW_CREATE=1’: MySQL server has gone away (2006)
mysqldump: Couldn’t execute ‘SELECT COLUMN_NAME AS Field, COLUMN_TYPE AS Type, IS_NULLABLE AS Null, COLUMN_KEY AS Key, COLUMN_DEFAULT AS Default, EXTRA AS Extra, COLUMN_COMMENT AS Comment FROM INFORMATION_SCHEMA.COLUMNS WHERE TABLE_SCHEMA = ‘gs_db’ AND TABLE_NAME = ‘gs_object_data_027046523320’ ORDER BY ORDINAL_POSITION’: MySQL server has gone away (2006)
mysqldump: Couldn’t execute ‘show table status like ‘gs_object_data_027046523338’’: MySQL server has gone away (2006)
mysqldump: Couldn’t execute ‘SET SQL_QUOTE_SHOW_CREATE=1’: MySQL server ha…
Hi Anouar_meallam,
SQLBackupAndFTP creates backups of your MySQL Server via the mysqldump tool.
The error message “MySQL server has gone away” is generated by the mysqldump tool and cannot be resolved via SQLBackupAndFTP. We recommend you to find more details on the web.
