Hi all,
I use the application several years and never had any problems; it’s a very easy to work application.
But since this morning The FTP section of the application stops working; testing the connection freezes. If I use Filezilla with the same user and password etc I use in SLQLBackupAndFTP I can simply connect to the desired folder. But within the application FTP is no longer possible.
So I did a re-install, reboot (several ones) but nothing makes the FTP work again. Again FTP through Filezilla (of any other software) works fine. So any ideas? Can it be something to do with perhaps an IPv6 address on the client and the server? It has not been change for as I know and till this morning every backup was tranfered through FTP to the desired FTP server.
I hope that somebody has any idea or a working solution.
thanks Walther
yes: it’s Windows server 2022, SQL server 2019 Standard and SQLBackupAndFTP version 10.2.14 (and yes it is not the latest version but before any upgrade I need to be sure it will work (again).
and some more info that could be important: the application works fine; back-ups are made in the local folder. Then the application tries to connect to the external FTP server but stops with a time-out. The first thing I did was of course check the FTP server. As I said I could connect with the same credentials I use in the application to the FTP server. So I could rule out that the problem lies with the FTP server. Only other cause could be the application ergo SQLBackupAndFtp.
