Feature Request - Ability to Set Individual Retention Policies for Folder Backups
Hi, we have a feature request.
Just like separate retention policies (delete backups older than) for separate databases, it would be very helpful if the same can be configured for folder backups.
Hi PRESS_FIT_PIPE_AND_P,
Thank you for your request.
You can create multiple backup jobs and set an auto-delete option for your backups for each of your backup jobs.
We thought of the same. It is a workaround and are currently using it.
But please note that there are 2 issues with it:
  1. A system of multiple jobs is easier to set up but difficult to maintain.
  2. When the purpose is folder-level backups, the jobs fail when we don’t select a database to be backed up. Due to this, we are forced to backup a systemDB or dummy DB alongside.
Although it is workable, it’s not a “clean” solution like the rest of the product.
A separate retention policy for Folder backups would be a very useful feature.
Hello PRESS_FIT_PIPE_AND_P,
Thank you for your reply.
According to the second point, there is no need to select a system database to backup if you need to backup only local files and folders. Just connect to DBMS and choose local files and folders you need to backup.
Thank you. I checked it and it worked. Earlier, we used to get an error that no DBs have been selected.
That’s great! Thank you for your reply.
