I installed sqlbackupandftp 12.3.10 Trial on newest and completly updated Windows 10 and try to configure a backup job.
Unfortunately I alreaday fail doing the db connection test to a postgres data base, system complains with error code -1073741502.
Log says:
14:28:30.8062|DEBUG|6|Net.Pranas.SqlBak.Job.CliConnection.CliConnectionHandlerBase|ExecuteQuery. Unsubscribe error callback.
2020-03-05 14:28:30.8062|DEBUG|6|Net.Pranas.SqlBak.Job.CliConnection.CliConnectionHandlerBase|ExecuteQuery. Check exit code.
2020-03-05 14:28:30.8062|DEBUG|6|Net.Pranas.SqlBak.Job.CliConnection.CliConnectionHandlerBase|ExecuteQuery. Exit code: -1073741502. Generate exception.
2020-03-05 14:28:30.8062|ERROR|6|Net.Pranas.SqlBak.Job.CliConnection.CliConnectionHandlerBase|ExecuteQuery|System.InvalidOperationException: cmd has exited with -1073741502 code.
bei Net.Pranas.SqlBak.Job.CliConnection.CliConnectionHandlerBase.ExecuteQuery(ProcessStartInfo startInfo, CancellationToken cancellationToken)
2020-03-05 14:28:30.8142|ERROR|6|Pranas.Net.SqlBak.Service.Client.Content.Ext.JobCredentialsExt|TestImpl|System.InvalidOperationException: cmd has exited with -1073741502 code.
Do you have any idea what to do?
I can connect to the database using psql and same user
Log was sent to you via “send log to developres”
Thank you very much, Peter
