Tried to restore to my hosted (simply.com) database:
2024-02-06 23:01:28 [Error] Failed to restore “angavangen_se_db_testlager” database. T-SQL command error: /* ==Scripting Parameters==
Source Server Version : SQL Server 2019 (15.0.4003)
Source Database Engine Edition : Microsoft SQL Server Standard Edition
Source Database Engine Type : Standalone SQL Server
Target Server Version : SQL Server v160
Target Database Engine Edition : Unknown
Target Database Engine Type : Standalone SQL Server
/****** Object: Database [angavangen_se_db_planklager] Script Date: 2024-02-06 22:31:20 ******/
CREATE D…er]
CONTAINMENT = NONE
ON PRIMARY
( NAME = N’angavangen_se_db_testlager’, FILENAME = N’D:\SQL\angavangen_se_db_planklager.mdf’ , SIZE = 51200KB , MAXSIZE = 15728640KB , FILEGROWTH = 51200KB )
LOG ON
( NAME = N’angavangen_se_db_testlager_log’, FILENAME = N’D:\SQL\angavangen_se_db_planklager_log.ldf’ , SIZE = 51200KB , MAXSIZE = 2097152KB , FILEGROWTH = 51200KB )
COLLATE Danish_Norwegian_CI_AS
WITH CATALOG_COLLATION = DATABASE_DEFAULT
CREATE DATABASE permission denied in database ‘master’.
What should I ask them to do?
