12:40:40 : ERROR: Failed to backup “coeminna” database with “Full” backup type: Failed to create database dump > Unable to read data from the transport connection: The connection was closed.
Hello Muazu_Babangida_Adam,
It seems this is a network issue. Could you please contact your network administrator to check the problem?
When your SQL Server backup failed with the error “Operating system error 5 (Access is denied.)”, this usually means you are not authorized to write data to the destination path. Then you can troubleshoot the following causes one by one: Your login account of MSSQL does not has full permissions to the target directory.
Hope you find this helpful,
James
Hi James,
Yes, that is correct.
