ERROR: Can't allocate required memory!
Here is the modified version of your error log for sharing on an online forum, with the database name replaced:
07-10-2024 02:28:20 [Error] Failed to backup “DB_NAME” database with “Full” backup type: 7-zip archiver error. > (8)
7-Zip 19.00 (x64) : Copyright (c) 1999-2018 Igor Pavlov : 2019-02-21
Scanning the drive:
1 file, 4929720320 bytes (4702 MiB)
Creating archive: F:\Temp\Pranas.NET\SQLBackupAndFTP\backup\DB_NAME202410070226.7z
Add new data to archive: 1 file, 4929720320 bytes (4702 MiB)
Enter password (will not be echoed):. Error:
ERROR: Can’t allocate required memory!
Why i am getting this error?
Hello Naushad,
The error you are encountering is related to the 7-zip utility, which is running out of memory for some reason.
We recommend trying to adjust the 7-zip parameters (as shown in the screenshot below) to reduce memory usage. This might include lowering the compression level, changing the dictionary size, or using multi-threading options.
Kind regards,
Oleg
