Error: /bin/sh: 1: ./sqlpackage/: not found
ello All,
I’m working to setup Sql backup for Azure SQL DB , i’ve deployed sqlbackupandftp on ubuntu registed my VM and established a connection to the DB . But when starting a backup job a got an error
sqlbak -rj -ji 48367
Starting scheduled job “New Backup job” - “FULL”. Server “sqlbak-poc”. Account “XXXX”. App v.“1.6.17”.
The backup folder “/tmp/sqlbak/sqlbak_t/b_48367_0908114449/” has “55.653GB” free space. The temporary folder “/tmp/sqlbak/sqlbak_t/b_48367_0908114449/” has “55.653GB” free space
Backing up “sqlbak-DB” database to “.bacpac” file.
Job execution error: /bin/sh: 1: ./sqlpackage/: Permission denied
Cleaning up backups of “New Backup job” job
Handling a console command has failed. .
Can you help me ?
Hi Bilel,
To resolve the issue, please specify the path to sqlpackage utility via –update-settings
Hey @Alexander,
Thanks for your replay the problem has been solved but i got another error related to certificate
The backup folder “/tmp/sqlbak/sqlbak_t/b_48367_0914101907/” has “55.423GB” free space. The temporary folder “/tmp/sqlbak/sqlbak_t/b_48367_0914101907/” has “55.423GB” free space
Job execution error: *** Error exporting database:Could not connect to database server.
A connection was successfully established with the server, but then an error occurred during the pre-login handshake. (provider: TCP Provider, error: 35 - An internal exception was caught)
The remote certificate is invalid according to the validation procedure.
This is my connection strings
Server=tcp:sq.database.windows.net,1433;Initial Catalog=sq;Persist Security Info=False;User ID=xxxx;Password={your_password};MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;
Could you help me to fix it ?
Bilel
Hi Bilel,
The application connects to Azure SQL databases using the sqlpackage utility, please find more details at Download and install SqlPackage - SQL Server | Microsoft Docs
Could you please try to make a dump using this tool, and if it works, please let us know what parameters you use during the connection?
